1995 4x4 idle fluctuates and vehicle stalls
Old 01-09-2017, 03:26 PM
jsegotta's Avatar
jsegotta is on a distinguished road
Default 1995 4x4 idle fluctuates and vehicle stalls
I have a 1995 blazer 4x4 4.3 vortec engine. Vehicle started sputtering going down the road. It would then run fine. when in park idle will go from 800 rpm to 2000 rpm almost die then rev up again on its own. I was told it was a computer issue. replaced engine computer. replaced fuel filter and pump, accelerator position sensor. i still get code for sensor and oxygen code. when vehicle is first started it seems to run ok until it warms up then i start having the problems. any help appreciated
Old 01-14-2017, 09:46 AM
wickedbrisket's Avatar
wickedbrisket is on a distinguished road
I had same prob. Pulled and tested O2 sensors after cleaning them. They were gummed up with egr soot. Luckily after cleaning the sensors tested out fine. Re-installed them and then blocked off egr valve with home-made aluminum can gasket that would not allow gasses to re-circulate. I also installed new distibutor rotor, cap, and iridium plugs with new plug wires while I was at it. Now my Blazer runs like a top again!
BTW I also have a 1995 4 door 4 X 4 with of course the 4.3 vortec
FlyingFinn81
11-30-2013 12:26 PM
benman
08-29-2012 12:45 PM
deerhunter53
08-06-2012 10:35 PM
cluckerr
05-16-2012 09:25 AM
KyleS4562
03-02-2011 06:09 PM
Quick Reply: 1995 4x4 idle fluctuates and vehicle stalls
