99 Blazer t-5 swap
99 Blazer t-5 swap
hi i have a 99 Blazer LS 4x4 auto, and my 4l60e just took a dump on me. i have a t-5 from a 86 blazer 4x4, but with the 2.8. is a swap possible on my 99? what modifications would be needed? thanks!
Based on cost only my guess is NO.
A 96+ is designed for the NV 3500 manual transmission.
Tomorrow we plan to fire up our 1998 engine/transmission implant for the first time.
We when from 1998 X with 5-speed behind it to 1998 W VIN's that had a 4WD auto behind it and mated it to another 1998 5-speed with 400,000 fewer miles and physically everything was bolt compatible.
I do not know if a 5-speed 4WD NV 3500 will be a direct bolt in option. I would consider buying a wreck so you have all of the change over parts required.
We found no oil pan or exhaust manifold differences between the X engine from the 2WD 5-speed and the 4WD automatic with the W VIN engine as some stated we would. experience.
94BlazerGirl
08-28-2014 06:14 PM
PogiMoto
06-02-2014 11:31 AM
Phillips8201
03-16-2010 10:26 AM
