I need help!
Old 10-31-2014, 01:44 PM
bigtiny's Avatar
bigtiny is on a distinguished road
Default I need help!
I just bought a 2000 Blazer 4x4 and it has sat for over a year. I did a tune-up ( plugs wires cap pcv valve oil and filter air and fuel filter) it still has a miss! My trans has begun not to shift.. I can manually shift it but it will not down shift by itself.. And while going down the hwy if I try to pass someone it will just putt and not downshift... Any suggestions would be greatly appreciated... Thank you in advance..
Old 11-01-2014, 08:59 AM
abarone7411's Avatar
abarone7411 is on a distinguished road
Mine is a similar problem. Are you sure you gapped all the plugs right? Mine has a blown intake gasket that I have to replace. Are you leaking coolant as well?, it might have something to do with that because they are known to go bad. I would fill it up with coolant and see if it leaks out or if your coolant is already low it may be the issue.
Old 11-01-2014, 09:06 PM
bigtiny's Avatar
Plugs are gapped correct and intake gasket was replaced a couple of months before it was parked... I have checked all fluids and they are all correct... Transmission is my main concern though... Good luck with your issues
1hugeblazer
02-21-2011 06:05 PM
maximashift
11-17-2009 09:36 AM
maximashift
11-17-2009 09:33 AM
blazin4eva
01-27-2005 02:02 PM
Quick Reply: I need help!
