Jerking C1500 at Highway Speeds
Hey guys it's been a while but I need some help. I have a 1995 GMC C1500 with the 350 and 4L60-E transmission. During highway speeds (40 mph and up) the truck jerks almost as if it is jerking like a bucking bronco. During this there is no loss in RPM or oil pressure. Only happens when I'm lightly getting on the gas to go up hill (between 1300-1500 RPM) or to pass someone. Goes away if I hammer on the gas and get above 1500 RPM. Anyone have any ideas? Any help is appreciated
The fluid in the tranmission is full and the fluid is nice and clean. It's weird it has the feeling of the loss of power but the rpms don't go down. I was wondering if it could be something in the rear end
ah cool. less pita parts to fail.
Ive got tbi as well. I do remember feeling mine pull back like that and the grey connector was loose on the coil. I had broke the clip that holds it on and it had slid partially off. See if you have the same issue.
Have you tried readjusting the detent cable for the trans?
