Runs rough till warm
Ok, got a 95 blazer and a few months ago whenever I started it, it would run fine for a minute, then it would start idling erratic. It would fluctuate between 600 and 1100 rpms and would keep doing it for a few minutes until it warmed up. This happened every other time I started it. As of a month ago it does it every time I start it now and continues to run rough and will have no power and jerk around while accelerating unless I step on it until 3000 rpms. It would run like this until it warmed up more then run fine. I just replaced the engine almost exactly a year ago and has been giving me on and off problems ever since, this being the first problem since July when I replaced the injector AGAIN.
New parts include: Fuel pump, fuel filter, injector, timing chain and gears, distributor, cap and rotor, spark plugs and wires, ignition coil, knock sensors, MAP sensor, and TPS.
I have checked and cleaned both the EGR and Idle control valve and nothing has helped and has no vacuum leaks that I can find. I am at a complete loss, any help or suggestions would greatly appreciated before I pull out the rest of my hair.
Thank you!
Thank you!
bam_9_9_9
49
12-30-2012 08:42 PM
jrakers2
03-22-2012 06:29 PM
bdlivengood
06-05-2011 11:06 AM
DoubleDouble
04-13-2011 11:34 AM
THOMA8d
08-13-2010 09:03 PM
