how to get roofrack off
Old 01-18-2010, 04:12 PM
couldbeanyone's Avatar
couldbeanyone is on a distinguished road
Default how to get roofrack off
hi i was wanting to take my roofrack off bc i'm thinking about lowering it 3" and thought it might look better ..I looked at what i might need to get it off and it looks like a star screwdriver? i tried one i think might have been to small..and it kind of messed the head of the screws up am i using the right tool? was i not using the right size or what?
Old 01-18-2010, 04:26 PM
Sisk's Avatar
It's called a torx screwdriver. They have a tendancy to strip really easily though. If you've stripped the screw the only way to get it out would be to drill it out.
Old 01-18-2010, 05:30 PM
k well looks like i'll have to drill a couple out ..what size drill bit should i use?is there anything i need to know before trying to remove the others or are they just going to strip also...do i need to be careful how far i drill them down so i don't poke through the headliner? what can i do for covering up the holes besides welding that would be simple?
Old 01-18-2010, 05:33 PM
The_Beast's Avatar
The_Beast is on a distinguished road
It's a real PITA. I stripped the bottom screw closest to the taillight when I re-painted my tire carrier. It took a hole behind the taillight, a weeks worth of soaking in PB blaster, and a screw extractor to get it out. Ohh yea and $8 to replace the screw
So be careful
Old 01-18-2010, 06:55 PM
blazeitupdrgonzo's Avatar
blazeitupdrgonzo is on a distinguished road
Im not sure how to go about taking off the second gen roof rack but when I took off the roof rack on my first gen Blaze I just filled the holes with lots of BONDO and sanded it down to smooth.
Old 01-18-2010, 07:11 PM
are the holes going to be big?
how big of a drill bit will i need to drill the ruined screws out?about as big as the head of the screw?
Old 01-18-2010, 07:56 PM
Sisk's Avatar
The holes are as big as the screws. It's nothing major, but they are a decent size.
I'd recommend welding it over using bondo to fill it. Although it's a hell of a lot more work it will last longer and probably look better if done right. If you plan on doing that keep in mind you'll have to get a full body paint job. If you just paint the holes you'll never get it matched.
Old 01-18-2010, 08:18 PM
cbr995's Avatar
Sure you can get it to match. That's what feathering does. It lets the new paint flow into the old making it much harder to notice.
Old 01-18-2010, 08:55 PM
is there anything maybe i could read on "feathering" or maybe even the whole process?
Old 01-18-2010, 08:58 PM
cbr995's Avatar
you could google "feathering in automotive paint", or look for it on youtube.
But I would suggest having it done by a pro that knows how to do it.
Quick Reply: how to get roofrack off
