LED lighting upgrade 1st gen Blazer
Old 03-21-2015, 07:20 AM
MyWorkInProgress's Avatar
MyWorkInProgress is on a distinguished road
Default LED lighting upgrade 1st gen Blazer
Hey everybody! I've been searching the threads and good ole Google and I haven't found what I need so far so I've come for help.. My '94 Jimmy has adequate lighting inside I guess but I'm interested in changing over to LED and I just want to know what bulbs you guys have used to do so, I have a 4 door with the overhead console with the 2 little "eyeball" lights and the dome lights, and the footwell courtesy lights, and map lights in the mirror. Now I know the dome/map lights are the same but I'm not sure how to remove the "eyeball" lights, the footwell lights are single contact bulbs I'm not sure what # though. Also interested in doing the cluster lights and HVAC lights so whatever you guys got I'd appreciate the help thanks!
Old 03-22-2015, 07:09 PM
richphotos's Avatar
richphotos has a spectacular aura aboutrichphotos has a spectacular aura aboutrichphotos has a spectacular aura about
www.superbrightleds.com enter your vehicle ect and it will list all the bulbs.
Old 03-23-2015, 06:08 AM
Alright sweet thanks another thing I've been looking for is a clear dome light lens to replace the old opaque factory one in my overhead console does anyone know where to find them? LMC only has them for the pickups.
Old 03-23-2015, 02:52 PM
richphotos's Avatar
That I am not sure of. I personally have not seen a clear dome light lens.
Old 03-29-2015, 05:49 AM
Thogert's Avatar
Could try making your own out of acrylic. Not sure on the shape, but a dremel, time, and patience can usually net some pretty good results.
Old 08-02-2016, 11:23 PM
4corners's Avatar
4corners is on a distinguished road
I want to change my overhead lights also but I can't figure how to get the lenses off of the map lights and dome light. The dome looks like it just prys off but it seems to resist and I am afraid I will break it. The map lights, I have no clue.
Old 08-03-2016, 01:33 PM
richphotos's Avatar
There should be a slot to put a flat blade screwdriver in the dome light to pop it off.
The map lights, push and turn and they will come out.
MyWorkInProgress
02-07-2015 03:57 PM
1989Blazin
02-06-2012 12:23 AM
xgiovannix12
08-21-2011 04:21 PM
uhlhazard
01-05-2011 01:08 PM
Blazin_Jason
09-08-2008 07:58 AM
Quick Reply: LED lighting upgrade 1st gen Blazer
