Suspension Tech Have a question about modifying your suspension? Ask it here.
4x4... possible to lower?
Old Aug 22, 2005 | 02:00 PM
LowRidinBlazer's Avatar
LowRidinBlazer is an unknown quantity at this point
Default 4x4... possible to lower?
Like title says, I have a 94 Blazer 4x4 and i wanted to know if its possible to lower them since their 4x4 and if it is possible, does anyone know of a good lowering kit or recommend something... kinda new to blazers so any info. is appreciated
Old Aug 22, 2005 | 03:18 PM
timetoblaze's Avatar
Default RE: 4x4... possible to lower?
its possible to lower them... i have my 99 4x4 lowered 3" all around the only lowering kit i found was through belltech im not sure if there are more for your yr... just keep checking aftermarket parts sites
Old Aug 22, 2005 | 03:33 PM
Thanks... I found 2 Belltech kits for my year... one for $369 and another for $139... neither include shocks but what else is the difference between them that the price is so different... anyone experienced either or know backround about it? Thanks again
Old Aug 22, 2005 | 05:52 PM
whats included in both kits? mine was 300 all together 150 for the kit and the rest for shocks....kits inlcuded torsion bar key blocks u bolts bump stops instructions not much to it
Old Aug 22, 2005 | 11:46 PM
zero psi's Avatar
Retired Admin
ive seen a bagged and bodydropped 4x4 blazer and he kept the 4wd operational. now thats some insane fabrication!
Old Aug 29, 2005 | 03:43 PM
Ok, I've found lots of kits that include shocks, blocks, spindles, and springs... I presume that is everything correct? Now, the question I have left is are 2WD and 4WD kits the same of is something different? A lot of the kits I found don't say between 2WD & 4WD... also, since I'll be dropping it the correct way, am I gonna have to worry about camber problems at all or nothing major? Thanks
Old Aug 29, 2005 | 04:14 PM
Ok, from what I gathered up so far, I can put blocks on the back with some nice shocks... but what I can't seem to find is a way to drop the front on 4WD 3-4in. Anyone know of a kit or part # i can search for? Thanks
Old Aug 29, 2005 | 05:17 PM
Ok... found a kit. Its Belltech's #BEL3913... includes blocks and torsion relocating kit, is this kit any good? Obviously I'll have to get a set of shocks and what not but if possible I wanna try and get some opinion's on this kit. 3" drop is all I want for right now, does anyone know if I'll have a camber problem or will I be fine? Thanks again
Old Aug 29, 2005 | 10:51 PM
zero psi's Avatar
Retired Admin
thats pretty much the only way to do a "bolt on" drop on a 4x4 is torsion keys and blocks or springs. if i were you, id spend the extra money and get the lowering springs for the back. they're more durable and will ride a lot better. as far as your alignment concern...you'll definatly need an alignment whenever you lower (or lift) a vehicle. otherwise you'll go through tires like nothing.
piedpiper27
Lowering Tech
14
Dec 19, 2009 02:44 AM
blazer206
Lowering Tech
Jan 3, 2009 07:13 PM
guitarman
Lowering Tech
14
Jan 2, 2009 11:38 AM
boomtruck97
Suspension Tech
Sep 8, 2006 02:56 PM
V6 Vortec Jimmy
Feb 17, 2006 05:02 PM
