Sqeaking sound?
Old Jun 18, 2009 | 10:59 PM
Dymisamo's Avatar
Dymisamo is on a distinguished road
Default Sqeaking sound?
There is a squeaking sound coming from my engine compartment. It squeaks about once every rotation of the belt. I'm not much of a mechanic but a little advice will help me understand what is wrong with my blazer. Its a 2002 Blazer Xtreme 4.3L. I recently took the belt off and put it back on because I changed the alternator. Any advice would be greatly appreciated
Old Jun 18, 2009 | 11:39 PM
AJBert's Avatar
Could be the bearing in the alt you just installed if it wasn't there before. You could try removing the belt and starting it up to see if the squeak is still there. DO NOT RUN YOUR ENGINE FOR MORE THAN A MINUTE OR TWO!!! As long as your engine doesn't get up to temp and your battery is fully charge this will not hurt anything.
If the sqeak dissappears then you will know it has something to do with the belt, ie: alt, water pump, power steering pump, idler, fan clutch or a/c compressor. Don't think I left anything out.
Then again, it could be the belt itself...lol
Old Jun 18, 2009 | 11:42 PM
Dymisamo's Avatar
okay, I will attempt that tomorrow, take the belt off and run the engine for a second cold and see if the squeaking is still there. I will let you know
Old Jun 19, 2009 | 10:39 PM
Dymisamo's Avatar
Thumbs up
I did what you told me to and took the belt off and started the engine and there was no squeaking. I put the belt on and everything ran fine. thanks for the help
Old Jun 22, 2009 | 11:31 PM
nasty187's Avatar
nasty187 is on a distinguished road
the belt sometime gets dry and will squeek,at my work we put a lil vasoline on both sides of the belt and that usually helps keep the belt squeek free
phate422
14
May 24, 2011 09:36 PM
MuTaLiZeD
Apr 3, 2011 08:07 PM
ryanhawk
Apr 7, 2010 01:50 PM
greenbean
May 8, 2009 10:36 AM
lemon blazer
13
Sep 12, 2007 09:35 AM
