somethin is up with my amp
Old May 22, 2006 | 01:32 AM
b_lazer's Avatar
b_lazer is an unknown quantity at this point
Default somethin is up with my amp
alright yall my amp is a bostwick 300 watt amp pushin two bostwick 12" spl powers and like two days ago i started blowing fuses and since then i have blown like 8 fuses but they only blow on this one song soooo i think i need a capicter so could yall give me some help
Old May 22, 2006 | 02:19 AM
97blazer44's Avatar
97blazer44 is an unknown quantity at this point
Default RE: somethin is up with my amp
Are you blowing fuses on the amp, or on the power wire. Check for bad ground, or see if your power wire has a hole in it, because it could be grounding out somewhere.
Old May 22, 2006 | 02:25 AM
XBlazer01's Avatar
XBlazer01 has a spectacular aura aboutXBlazer01 has a spectacular aura about
yea Check your ground and make sure thats all fine.
Old May 22, 2006 | 04:49 PM
Binz316's Avatar
Binz316 is an unknown quantity at this point
ground wire, and make sure all exposed wires aren't touching any metal; they could have come lose through travel
Old May 24, 2006 | 05:02 PM
blazin97's Avatar
Sounds like your power wire is shorting out. Check where it runs into your truck from the engine bay, thats where it probably is.
JohnBarJB
Sep 28, 2020 07:34 PM
97Bravada
Suspension Tech
Jul 10, 2010 03:34 AM
97Bravada
Jan 20, 2010 07:38 PM
TheBrettster
May 9, 2008 02:14 PM
RCarp48
Apr 2, 2007 07:19 PM
