rear window in tailgate won't go back up
Old Nov 9, 2009 | 05:32 PM
87muddyblazer's Avatar
87muddyblazer is on a distinguished road
Default rear window in tailgate won't go back up
I have an 87 blazer K5 with an electric window in the tailgate that didn't come with the truck. It was working fine till one day I put it down, now it won't go back up.
I took off the back panel and thought it was the drive cord/shaft coming from the motor that was stripped but it is on the other end of that cord under neath the window that is the problem.
I can't get the window up manualy to get at the other end of the cord to try and fix it.
any help and I would be very thankful.
Old Nov 9, 2009 | 09:04 PM
Sounds like the cable has stripped out at the regulator. If you disconnect the cable from the motor and hook your drill to it, can you make the window go up?
Old Nov 10, 2009 | 05:59 AM
It is stripped on the other end of the cable underneath the window
e602
91
Mar 8, 2015 04:53 PM
RobRad
Mar 24, 2014 06:08 PM
dlippiet
Oct 10, 2010 11:14 AM
mwjungaz
Aug 24, 2006 09:10 PM
sleonh
Mar 29, 2005 03:32 PM
