96 Jimmy help new rims and tires! make sure they fit!
Ok i have these rims
Product Line Eagle Alloys 118 Series Wheels
Rim Diameter 15 in.
Rim Width (in) 8.00 in.
Backspacing (in) 3.750 in.
Offset (mm) -18.00mm
Wheel Material Aluminum
Wheel Finish Polished
Lug Nut Seat Style Conical seat - 60 degree
Hub Centric No
Load Rating (lbs) 1,900 lbs.
im about to get the PA 2"Body lift
and the 2" shackles
i have the t-bars cranked 1.5"
i was wondering after all of that can i fit the new
Wrangler Authority 31X10.50R15LTC 109Q
on them without rubbing issues on road and some muddin!
i still have the stock gmc rims from 96
or if not im also looking into the crager soft 8's.
thanks for the help guy's!
Rim Diameter 15 in.
Hub Centric No
and the 2" shackles
as long as the lug pattern is 5 x 4.75 you should fit. As for rubbing Issues... you may need to trim some fender. 3.75 backspacing is 2.25 less than you have now, & the rim is wider....
that will be your only drawback wheel wise. everything else has worked for others here. your lift : tire ratio seems to work for others. Just watch the back spacing. as a rule, the closer you get to 6" the better. It is hard to find that high of BS for aftermarket rims though....
yes i have those Eagle Alloys 118 rims on it now with 235x75rx15's and had to crank the t-bar to stop rubbing. as you can see by the pic below!
31's aren't going to fit without MAJOR rework of the fender/firewall. Even with stock rims, 31's just do not fit (unless you find special 31's that are 29" diameter like another member).
With the back spacing being that low, you are going to run into even more interference.
i kno that but as i have stated the setup i saw over there is a NON ZR-2 its just like mine they say it will only rub on Full Lock! with stock 96 rims with 6" bs
well Justin from synergy offroad just answered my question if i use stock i can!
Hey Cory,
You sure can! I did this very combination on a 2dr 1997 blazer awhile back.
Thanks!
Justin synergy offroad
Sent: Wednesday, November 18, 2009 2:25 PM
To: <synergyoffroad@gmail.com>
Subject: Contact Us Requested
> You have received a contact request from a visitor to your storefront:
> Request:
> ok if i install ur performance Accessories PA132 Chevy Blazer/ GMC Jimmy 2 " Body Lift
> Fit 1995-1997 Chevy Blazer and GMC Jimmy's including ZR2, Z85, and ZM6.
> Lift your truck 2 "
> Made in the USA!
> if using stock rims on a 96 gmc jimmy
> can i run 31x10.5x15 tires with the lift
> i also have a 1.5" t-bar crank on it already. i am also thinking about using your 2" shackles .
Hey Cory,
Thanks!
> Request:
> Lift your truck 2 "
> Made in the USA!
