What can i easyily do for a HP gain?
Old Apr 20, 2005 | 01:47 AM
FatRyan's Avatar
FatRyan is an unknown quantity at this point
Default What can i easyily do for a HP gain?
I would like to get a bit more umph in my blazer, but i dont want to go big cause i dont have big $$$. i also dont want to viod my warranty. any ideas? i already have an AEM brute force CAI, and i plan to get custom dual exhaust. but what else can i do?
Old Apr 26, 2005 | 11:58 PM
dobbist's Avatar
dobbist is an unknown quantity at this point
Default RE: What can i easyily do for a HP gain?
i highly recomend a msd ignition i think my 6a cost me around 200 bucks so not too bad and a definate impovement adding a wiring adapter makes the install a lot easier but its a simple install as is and tossing in a msd igniton coil will help a little and there around 50 to 100 depending on which one you get also go to s-10planet.com and pick up an egr mod. i have also heard about people taking off the throttle valve off the throttle body ( that thing that controls how much air goes into the engine) but i dont know if i recomond it since that might lower your gas mileage and if you screw up doing it a new throttle body is expensive.
Old Apr 27, 2005 | 02:11 AM
FatRyan's Avatar
ok cool thanx
Old Apr 27, 2005 | 03:27 AM
dobbist's Avatar
oh i just remembered one more that i havent done just because i dont trust the idea to much but other people have removed the screen from their mass air flow sensor but if you already have an cai you might have took that off i dont know just another idea. but yeah check out s10planet since a lot of the s-10 and s-10 balzer are pretty identical when it come to the engine.
ok actualy im having a hard time finding that egr mod site so as soon as i do i'll post the adress for you unless some one else does first
Old Apr 27, 2005 | 02:42 PM
FatRyan's Avatar
ok cool. thanx
Old Apr 27, 2005 | 10:08 PM
Patrick's Avatar
Patrick has disabled reputation
i wil second the MSD ignition...6A is great...i ran that on my 500+hp car...
Old Apr 27, 2005 | 10:49 PM
FatRyan's Avatar
sweet sweet. how hard is the install? how much HP can i expect to gain?
Old Apr 27, 2005 | 11:48 PM
dobbist's Avatar
the ignition to install just have to hook up a pos and neg wire to the battery and then either splice it into the existion wires to the coil or get the adapter which just plugs in with color coded wires as for hp propably 5 maybe 10 all depends on how stock and which msd model you go for torque will be about the same.
well i found it again took me 2 hours so heres the link to the egr mod
http://gallery.bcentral.com/GID46242...R-Limiter.aspx
but im still a little unsure how to install what the hell is the egr tube?? i thought you had to take off the air conditoning unit but i guess not so if anyone has done this mod if they can explain the process in detail i would apreciate it also for buying it would you just buy for a blazer? since i think you have to have atleast a 96 would that be a s10 blazer or what?
Old Apr 28, 2005 | 12:03 AM
zero psi's Avatar
Retired Admin
the cheapest thing to do is weight reduction.
Old Apr 28, 2005 | 12:11 AM
dobbist's Avatar
are you kidding do you know how much a fiberglass or carbon fiber hood cost? not to mention any other panel replaced to lighten it
