Weld rear end?
Weld rear end?
99 Blazer, lifted about 2 feet, jeep wagoneer front axle, ford explorer 8.8 rear, sitting on 35s. The traction on the rear end is pretty pathetic honestly... Can't even make it out of my snow covered driveway in 2wd (granted its slightly uphill). Always get slip with one tire spinning. Its an off road rig only. I would like opinions on welding the rear diffetential. Would it be a good idea, or should I buy a locker? Like I said its off road rig only and I don't need any fancy lockers, just wondering if welding it would be a bad idea or if I should just get a full locker. Thanks!!
I found a lot of valuable info on DonLs "Axle Swap" at: https://blazerforum.com/forum/builds...le-swap-93991/
Getting something better than "Open" is the heart of the matter. Lockers, Posi-trac and the G80 Gov-loc are discussed here
I am a little too new to know how to make those smooth links with the thread name instead of the URL but I/m gettin there.
Yes I'm aware of those, I was actually thought about throwing a g80 axle back under it but then the lug patterns would be different. I would invest in a locker, but there's no point, I might as well look for a full size axle with a posi already in it. So I'm thinking about going with welding this axle just for now.
heres how i did mine like 8 years ago
just remember to leave one side open so you can get the c-clips out if needed too, on the other side i just welded the corners of the gears. for a offroad only truck it made the world of difference
also make sure you clean the heck out of the gears... even looking at that picture with all the oil in there i dont know how the heck its still holding
Yeah I did some more research and did a practice run on the gears of a spare diff my buddy had, that he will now throw into his Camaro lol. I just welded the 8 corners, didn't insert a plate. Did a nice preheat on it as well.
That looks like it'll be a pain in the *** to ever take that thing apart again. I probably wouldn't do it. I would wait for funds for a locker to do it right. But to each their own. And if its an offroad dedicated rig and going to be trailered all the time then why not.
