1985 s 10 blazeer
Old Jul 6, 2012 | 11:31 PM
troy33087's Avatar
troy33087 is on a distinguished road
Default 1985 s 10 blazeer
y do i have to keep my gas petal pressed to start it and as soon i i release it it dies any ideas
Old Jul 7, 2012 | 01:36 AM
Juss11's Avatar
Juss11 is on a distinguished road
Probbaly a vacume leak. Check to see if the vacume line from back of manifold to brake booster came off.
Old Jul 7, 2012 | 03:14 AM
Zzzblazer95's Avatar
Zzzblazer95 is on a distinguished road
Also the tps sensor could also be shot do a search on how to test it with a multimeter cheap and also easy to do if you have the meter that is. Is this a 2.5 or a 4.3 not sure what they had in the blazers back then however if its a 2.5 let me know i use to have one of those in my 88 s10 for years i cant remember what the same problem was im leaning towards something vacuum like stated already but im unsure i believe it was a vacuum leak i know when i had my 2.5 i cleaned the intake out alot and it ran like a champ.
Old Jul 7, 2012 | 11:21 PM
troy33087's Avatar
its a 2.8l carb with the vacuum leak thing i have a chiltons and haynes manual and my daigram for my truck is not in either of them
Old Jul 8, 2012 | 01:15 AM
neo71665's Avatar
85 is carbed and doesn't have a tps. 4.3 wasn't an option in s-series till 88.
Most likely a vac leak and/or the carb needs rebuilt. When you have the carb off if it still has the screen grid under it take that and throw it in the trash. That thing goes bad and causes problems most of the time.
Old Jul 8, 2012 | 02:47 AM
troy33087's Avatar
i bought a new one and those thangs are not cheaP
need a vacum diagram UDW cant find it in any manual nor a ood enough 1 online for me to understand
f1tzg3r4ld
Jan 3, 2010 11:54 AM
nutfluff
Nov 6, 2009 01:06 AM
Shade
May 17, 2007 05:16 PM
bludrmz_2003
Jan 26, 2007 01:31 PM
I8URVTEC
Jul 28, 2005 06:56 PM
