1991 s10 blazer-no power to fuel pump
Old Aug 26, 2011 | 08:13 AM
edgesr's Avatar
edgesr is on a distinguished road
Default 1991 s10 blazer-no power to fuel pump
Have battery voltage for 2 or 3 seconds at grey wire coming out of fuel pump relay. Had friend turn switch while I checked grey wire, to ground, at connector to fuel pump. No power there when switched on. Had 8.5 volts on sending unit, though. Any suggestions? How is wire routed from rear to front of vehicle? Thanks in advance for any help.
Old Aug 26, 2011 | 11:04 AM
chris015's Avatar
I bet its the relay. its located on the firewall above the brake booster. there will be 2 there,a ac relay and fuel relay. its the one on the left.
try this,swap the relays,they are both the same. see if u have power then. if you do,and your ac doesnt work,you found the reason why. they are like 12 bucks at advance auto.
Old Aug 26, 2011 | 04:01 PM
edgesr's Avatar
Chris015
Have already switched the relays. No help. I do have 2 or 3 seconds of battery voltage at grey wire coming out of the relay that goes to the fuel pump. Just not getting voltage back to the fuel pump. Seems that if the relay were bad there would not any voltage at all. I think that there is a broken wire or bad connection after wires leave engine compartment. Began tracing wires from back of vehicle and see that the fuel pump power wire is routed under the carpet with a metal strip over it. Does anyone know how these wires are routed through out vehicle?
Old Sep 4, 2011 | 07:24 AM
edgesr's Avatar
Working now. Found corroded splice in wiring harness.
Old Sep 4, 2011 | 07:36 AM
pettyfog's Avatar
Good for you! Where was that located, approximately?
Old Sep 5, 2011 | 08:43 AM
edgesr's Avatar
Followed the grey wire coming out of the fuel pump relay and going into the wiring harness that has the split plastic cover. Kept opening up the plastic cover, exposing more wires, and following the grey wire. Found a factory splice, covered by tape, that had 2 additional grey wires. This is where the corrision was. Had to open up about a foot of the cover to find the splice.
Now the engine is skipping pretty bad. Going to change plugs, dist.cap, rotor button and maybe wires maybe Wednesday. Will also be checking all vacuum lines. Will post finding.
Old Sep 5, 2011 | 10:24 AM
pettyfog's Avatar
Excellent! So future readers... check wires starting at FP relay.
BTW.. Suggest AC DELCO Plugs rotor cap. ACDelco wires OR hi-Po premium wires.
No store brand.
BouncingRadical
14
Nov 27, 2015 12:30 AM
88BlazerS104x4
Mar 28, 2015 04:55 PM
jfrust64
Jul 15, 2012 06:41 PM
1991Blazinbeast
Mar 4, 2012 09:52 AM
tim_dean
Jan 8, 2008 03:16 AM
