1991 S10 Blazer Fuel Pump Issue
Old Feb 25, 2012 | 08:15 PM
1991Blazinbeast's Avatar
1991Blazinbeast is on a distinguished road
Unhappy 1991 S10 Blazer Fuel Pump Issue
hello i have a 1991 S10 Blazer 4dr with a 4.3l auto and 4x4 in it i have replaced the fuel pump, the fuel lines, the fuel relays, and filter's and even put a new rear wiring harness in the truck and still the fuel pump refuses to even try to pump can someone please tell me whats wrong with my truck thanks
Old Feb 25, 2012 | 08:25 PM
chris015's Avatar
Let me guess. you purchased an aftermarket pump and didnt buy a ac delco?
Old Feb 25, 2012 | 08:31 PM
i bought the fuel pump from the local gm dealer so im not sure what brand of replacement pump gm uses
Old Feb 25, 2012 | 08:35 PM
chris015's Avatar
gm dealer as in the dealership its self? Good! they either gave you an ac delco or a delphi,both is fine. they rarely go bad unless they have 200k miles on em.
Sounds like you have a broken wire somewhere. or a bad ground. Have you checked to see if you have power coming out of the wire at the pump?
Old Feb 25, 2012 | 08:36 PM
I bought a new fuel pump from My local Gm Dealer and it doesn't say what brand it is other than GM on it went and got the box
Old Feb 25, 2012 | 08:39 PM
Yes i have Power in the system right down to the pump and everything else try's when i try to start the truck but im not hearing anything from the fuel pump and i'm not getting any fuel anywhere in the system should i take the pump back and get another one
Old Feb 25, 2012 | 08:43 PM
and when i put the new harness in the rear of the truck i mad sure to clean all the grounds because the former owner had been in there doing a crappy trailer wiring install and had tapped in to six different wires just to make it work so i replaced the harness thinking that was my problem
Old Feb 25, 2012 | 08:55 PM
chris015's Avatar
Almost sounds like the pumps bad. that rarely happens,but hey. its still just a plastic/metal part so it can happen. Try knocking a piece of wood against the tank. if it turns on then,you know its the pump causing troubles.
If you return the pump,ask the clerk if it was an delphi or ac delco.
Old Feb 25, 2012 | 08:58 PM
ok i'll try that 2mrw thank you for your help
Old Mar 4, 2012 | 09:52 AM
Mag-300's Avatar
Mag-300 is on a distinguished road
Have you been able to find your trouble?
I just read your post and made me think of a few years back.
I had a 97 s10 blazer that needed a fuel pump.
I bought one from the internet that was suppose to be oem.
Got it and installed it.Everything was good and back together.
When I went to start it the pump sounded quiet and weird.
It wouldn't start!
Upon further inspection the polarity was reversed.
Once corrected it ran great.
Hope you get it fixed if you haven't all ready.
BouncingRadical
14
Nov 27, 2015 12:30 AM
auto-bot
20
Oct 27, 2011 06:54 PM
edgesr
Sep 5, 2011 10:24 AM
97ssblazer
Oct 24, 2009 07:16 AM
tim_dean
Jan 8, 2008 03:16 AM
