key stuck in ignition
Old 07-16-2012, 12:24 PM
84BlazerS10's Avatar
Default key stuck in ignition
My key got stuck in the ignition while the truck was running the other day should I just replace the ignition lock cylinder?
Old 07-17-2012, 06:09 PM
cadaver666's Avatar
cadaver666 is an unknown quantity at this point
thats your best bet, same thing happend to my 94 while it was running. the part is only $15 at Autozone and takes about 45 min to replace.
Old 07-29-2012, 06:29 PM
Sorry it took so long to reply I changed the ignition cylinder but I have now noticed a few problems after replacing it. I notice there is a substantial amount of play in the steering wheel especially when turning right. Also when I took the horn cap off the wire came off and I can't seem to get the wire to stay down in the hole for it to make good contact.
Anyone have any idea how to fix these problems?
Old 08-10-2012, 09:47 PM
bam_9_9_9's Avatar
bam_9_9_9 is on a distinguished road
not sure why you have excessive play now hmm maby the steering wheel nut didnt get tight enough. but for the wire in the horn cap. there should be a whit plastic peice on the end of the wire that has like small pins comming out of two spots. you just push in and twist. but if thos pins are busted or the plastic is busted insit the collum then just tac it in with super glue.
Old 08-12-2012, 02:52 PM
bertrenolds's Avatar
bertrenolds has a little shameless behavior in the past
You should have just taken out extra car insurance and then left your truck in a bad part of town unlocked
Old 08-18-2012, 10:20 PM
Well I drove it around a bit after fixing it just to see and the play in the steering straightened out quite a bit but for some reason now there is a sound like plastic scraping when you turn left no idea what would cause that. I will have to take it back apart and inspect the plastic piece because I couldn't get it to fit back down in there when I tried it .
lol bertrenolds I would be pissed if someone ever stole my blazer or my daily driver for that matter.
bigjblaze
10-19-2009 07:11 PM
trettifire
10-03-2009 08:48 PM
Woods1478
04-25-2008 08:57 PM
klein
05-05-2007 04:03 PM
will5631
03-27-2007 10:50 PM
Quick Reply: key stuck in ignition
