A\C problems
Old Aug 18, 2005 | 02:50 AM
xjeepguy's Avatar
xjeepguy is an unknown quantity at this point
Default A\C problems
I have a little problem. My A\C works, but my engine gets really hot when I use my A\C, but only when I use the A\C. Also it makes a weird rubbing sound at idle when the A\C is on, like the belt is slipping. I checked the belt tensioner, and all seems fine, but it has been way too hot not to be able to use my A\C. A\C systems are the only part of the truck I dont know much about. Any help would be appreciated.
BTW: it is a 94 S-10 LT Tahoe blazer with a "W" engine.
Old Aug 18, 2005 | 01:00 PM
V6 Vortec Jimmy's Avatar
V6 Vortec Jimmy is an unknown quantity at this point
Default RE: A\C problems
Well A/C will make ur engine more hotter. I'm not sure how hott ur engine is getting? Is it over heating?? Like when u use heat it less problem for the motor but ac its more harder on the motor I believe??
Old Aug 18, 2005 | 02:08 PM
xjeepguy's Avatar
Yeah, she overheats. I expect it to heat up a little, but it really shoots up quick.
Old Aug 19, 2005 | 04:39 PM
Hanr3's Avatar
And your mechanical fan clutch works fine?
The a/c unit shouldn't add that much more heat.
Have you taken the serp belt off and spun all your pulleys?
Aanenson
Apr 14, 2011 09:12 PM
upblazer95
Apr 4, 2009 08:27 PM
