`92 S-10 Blazer- starts, rough idle
Old Mar 14, 2019 | 10:01 AM
joseph_ayotte's Avatar
joseph_ayotte is on a distinguished road
Default `92 S-10 Blazer- starts, rough idle
Hi, a new guy, here. My Blazer starts and runs rough and barely idles. It is the big V-6 and has a 2 barrel carb body. I noticed while under the hood, gunning it by hand that the left injector seemed to not be working at all. There was no gas coming out of it. Is this situation easily fixed (like taking it off and blowing it out with air)? Thanks. Joe
Old Mar 14, 2019 | 08:21 PM
mr.vls's Avatar
No you will not be able to clean the injector with air. You could swap the injectors from right to left to make sure it is the injector itself and not an electrical issue. Replacement Injectors are about $65 each. You could try to get an injector from the junk yard if price is a problem . The injector opens and closes with pulses from the ECM. There is no path for air. You can test the electrical pulse with NOIDS you can get at Harbor Freight.
Old Mar 15, 2019 | 06:02 AM
Thanks I will try switching injectors.
Old Mar 15, 2019 | 10:18 AM
go chevy's Avatar
Welcome to the Forum...
Old Mar 15, 2019 | 10:51 AM
Thanks
rockjock29bc
83
Aug 1, 2019 07:26 PM
jrakers2
Jun 6, 2012 10:11 PM
metallicaman1031
Jun 13, 2010 11:39 AM
psewell@gvtc.com
Sep 27, 2009 07:36 PM
FieroBob
Jun 12, 2005 10:52 PM
