180 vs 195 thermostat 85 w/89 4.3l
Old 01-30-2013, 09:23 PM
justblazin1's Avatar
justblazin1 is on a distinguished road
Default 180 vs 195 thermostat 85 w/89 4.3l
im new to the forum and doing a couple threads here. im going to be replacing the thermostat and i see there are a couple options. the 195 ,180 and even 160 degree. the truck is mainly used for around town plowing and sits most of the year. a couple times a year it is taken on the highway but thats it . why so many options? should i just stick with 195 which is probably the factory one? thanks
Old 01-30-2013, 10:31 PM
neo71665's Avatar
If you live in a hot area its ok to drop down to a 185 or 180. If you still have fuel injection don't go any lower. The engine and ecm is designed to run hotter than carbs to aid in the combustion.
If you live in a really hot area, its offroad only, been swapped to carb you could drop down lower. Been proven to hurt more than it helps even on old v8s but somebody always claim otherwise, your choice.
Old 01-30-2013, 10:48 PM
thanks so how about a 99 tahoe 5.7L same thing stick with the 195?
Old 01-30-2013, 10:58 PM
fuel injection 195
carb 195 or 180
from nj so weather is all over but only used for plowing so its cold out ...
i dont remember if it has fuel injection or carb but i think its carb. its my friends i have to check
Old 01-31-2013, 07:26 AM
chris015's Avatar
chris015 has a spectacular aura aboutchris015 has a spectacular aura aboutchris015 has a spectacular aura about
ive got a 91'. I ran a 180 for a year,then it went bad so i went ahead and switched to a 195. Made a difference in gas mileage and didnt notice any performance loss.
Old 01-31-2013, 09:23 AM
neo71665's Avatar
In NJ I would keep the 195 for heater to work faster.
I run 180s in both my fuel injected trucks but our summers are more humid and hotter.
Pretty much anything 86/87+ from GM is gonna be fuel injected unless some knuckledragger ripped it off and put a carb on it. If its also in NJ with yalls strict rules if its street driven I bet its factory.
Old 02-01-2013, 08:32 PM
neo i made another thread on a temp sensor i was wondering if you can check it out and see if you have an answer for that thanks
Old 02-01-2013, 08:39 PM
rexazz2's Avatar
195 IMO , more heat for keeping windows clear
Old 02-03-2013, 01:05 PM
this is actually a carb engine i found out with my own eyes today
Old 02-03-2013, 02:14 PM
neo71665's Avatar
A 99 model and somebody swapped out the ls based factory engine fuel injection for a carb.....wtf
Quick Reply: 180 vs 195 thermostat 85 w/89 4.3l
