1987 Chevy S10 Blazer 2.8
Old Apr 18, 2012 | 03:09 PM
Chivas1's Avatar
Chivas1 is on a distinguished road
Default 1987 Chevy S10 Blazer 2.8
My brother has a V6 2.8 Blazer with "service engine soon" light on. I tried to pull the codes using the paperclip and got the following: 1 slower flash followed by 2 faster (3 times) then 1 slower flash followed by 5 faster (3 times) the last one was 3 slower flashes by 4 faster (3 times) and then it went to 1 slower flash followed by 2 faster.
I read the forum and believe the code 34 is for the MAP sensor but have not found anything for the 15 code. Please help
thanks in advance
Old Apr 18, 2012 | 04:17 PM
RetroBlazer's Avatar
RetroBlazer will become famous soon enough
15 is Coolant Temperature Sensor Circuit Low Temp indicated
Old Apr 18, 2012 | 04:47 PM
Chivas1's Avatar
Thanks RetroBlazer will it be the same for a 1989 Chevy S10 Blazer 2.8 since i mest up on the year?? also, how do i turn the "service engine light" off after i change the parts?
Old Apr 18, 2012 | 07:15 PM
Yes, it will.
Unhook the batter or remove the ECM fuse for 30 seconds or so and then start it, put it in drive with the brake on for 5 minutes to do an idle re-learn.
Old Apr 18, 2012 | 08:41 PM
neo71665's Avatar
The code will clear itself if its fixed. Pulling power for 15 minutes will hard clear it tho
Old Apr 26, 2012 | 03:23 PM
Chivas1's Avatar
Originally Posted by RetroBlazer
Yes, it will.
What is the Idle re-learn process for stickshift?
Old Apr 26, 2012 | 03:30 PM
For a manual, just drive it.
Old Apr 26, 2012 | 04:44 PM
neo71665's Avatar
Odb1 doesn't have a relearn process.
Old Jun 6, 2012 | 12:55 PM
Chivas1's Avatar
We changed the MAP sensor and he is still having problems with the car reving up and down. any other suggestions?
thanks
Old Jun 6, 2012 | 03:03 PM
neo71665's Avatar
Pvc valve working?
No vacuum leaks?
