1987 s10 Blazer idle and take off problems
Old Aug 8, 2010 | 08:02 PM
deathspoet's Avatar
deathspoet is on a distinguished road
Default 1987 s10 Blazer idle and take off problems
I just bought a 1987 s10 Blazer 2 door with a 2.8 out of a 1992 s10. When your stopped the engine with sometimes rev up real high and then when your driving it will do the same thing. Also it hesitates really bad when you step on the gas. Any help would be great.
Old Aug 8, 2010 | 10:22 PM
deathspoet's Avatar
When I say It revs up high thats without putting your foot on the gas
Old Aug 9, 2010 | 02:36 AM
94BlazerPA's Avatar
94BlazerPA is on a distinguished road
sounds to me your Throttle position switch is going bad. but I could be wrong, I dont know much on the 2.8's.
Old Aug 9, 2010 | 08:57 AM
ohsofly's Avatar
Start with the easy stuff and check the vacuum lines for leaks. Use carb cleaner spray on their connections, if the revs go up a little you found a leak. Sometimes you can hear them hissing if its bad enough. Check condition of tune-up. Any obvious leaks or unhooked connections.
Old Aug 9, 2010 | 09:34 PM
deathspoet's Avatar
I'll check the lines I was also thinking the TBI might be bad the guy I bought it from has it kiinda rigged in there. Could the fuel filter be bad?
chevyblazer9588
Nov 20, 2012 10:40 PM
Majoraslayer
Apr 19, 2012 10:15 PM
Klturi421
Mar 23, 2012 03:02 PM
blazer chris
Dec 8, 2011 09:56 AM
bornla
Nov 28, 2009 11:55 AM
