1990 4.3 s10 blazer Runs fine then lethargic...
I have a 92 4.3 doing the same thing.. I posted a message on automotive forums dot com..
there seems to be a guy called "old master" that is quite good with chev stuff especially the older models. you might check out this place as well..
I love your video.. that exactly what mine is doing but not a good sounding..
good luck and be sure to let us know what you find on this problem
my shop guy is saying the computer may need replacing.. but the may is not enough to warrant the money.
Well i decided to tear apart the tbi module and rebuild it with a full kit. So far i found the fuel pressure regulator diaphram pretty bad off. Pics and results later guys.
Here is a vid after the tbi module clean/rebuild:
YouTube - ‪4.3 vortec‬‏
Unfortunately after all that work still no change. I found alot of dirt and a damaged fuel pressure regulator diaphram but nothing more. In the vid the motor is firmly at 190 degrees and the injectors appear to be spraying fine
