1991 4.3 blazer.water gushing out bottom of engine, and transmission probs?
Old Apr 28, 2009 | 11:03 AM
joeroket's Avatar
joeroket is on a distinguished road
Not always. It does not take much water to produce white smoke.
A coolant system pressure test may not show a blown head gasket if it is isolated to one cylinder and the valves are closed when you test it. Make sure you bump the engine 90 degrees or so and recheck. You can look for the presence of bubbles in your radiator as well, sometimes they are present sometimes not.
Old Apr 28, 2009 | 08:15 PM
TomSawyer's Avatar
TomSawyer is on a distinguished road
Change both valve cover gaskets, always change things in pairs, if one brake or one bulb or one gasket has gone bad then the other is soon to follow. As far as the A/C, if you have a solid ground and the system works but drains the battery, you most likely have wiring issues. If your battery looses charge when the system works as it should then you have a mild short that shunts the voltage to ground and thus drains the battery. In other words, some wire, somewhere, is allowing current to flow from the battery to ground, draining the battery. Good luck, wiring issuses always bite ***.
Old Apr 28, 2009 | 11:29 PM
chris015's Avatar
hmm...il look into that..The biggest thing right now is trying to find a bushing for the transmission linkage..no auto store here has it INCLUDING the dealership...
kmartin
13
Dec 27, 2014 10:30 AM
James Honey
Apr 17, 2013 03:51 PM
dano440
Jun 11, 2012 06:59 AM
Kellogg
May 5, 2009 01:33 PM
vdog
Jan 10, 2007 04:46 PM
