1991 s10 blazer. STALLS AND BACKFIRES
Old Aug 25, 2010 | 04:45 PM
Ck1500's Avatar
Ck1500 is on a distinguished road
couldnt agree more!! make sure you have fuel pressure!!! i had a similar problem, with my blazer, and it had me stumped for a day, and while changing the fuel filter i had the wife bump the kep for me, to make sure there was nothing in lines, and i noticed a different sound comming from fuel tank.. like a spraying sound.. so i dropped the tank and found the hose that connects the fuel pump to the sending unit had a hole in it, and was spraying the inside of the gas tank. i installed new hose, and truck fired up no problem.
hope this helps
Ck1500
Old Aug 26, 2010 | 11:27 PM
chris015's Avatar
Well..i gave in. Im having the fuel pump put in tomorrow for $60 from a friends shop. we will see if that fix's it. if not. im skunked.
Old Oct 16, 2010 | 09:58 PM
chucky blazer's Avatar
chucky blazer is on a distinguished road
u may also try and check the fuel filter. it could be all sludged up from sitting so long. but from the sounds of it when it needs a load it doesn't supply it. just like mr. vls says. i might be the fuel pressure regulator. i have heard of a bad ground on the pump cause issues as well
deerhunter53
Aug 6, 2012 10:35 PM
mattkc
20
Jul 9, 2011 12:14 PM
Iesa
Nov 17, 2010 08:38 AM
Finalman
Aug 8, 2010 12:35 PM
Bybsurfr32
Nov 1, 2009 06:50 PM
