1992 Blazer stuck in 4 Wheel Drive high
I recently brought a 1992 s10 blazer 2 door tahoe 4x4 back to life after being off the road for 2 years.. I just got it inspected and the brakes done its working good.. But the truck is stuck in 4 High since i got it. It is push button electronic 4x4 and the switch is not lighting up at all and is not working ... i dont think that it is getting power... any ideas on how to fix i'd really appreciate... are there any other ways to get into 2 wheel drive if the switch won't work? thanks alot guys...
RE: 1992 Blazer stuck in 4 Wheel Drive high
Hi,
See the suggestions posted on this question
1998 Blazer Transfer stuck on 4x4
good luck
mike
good luck
mike
Checking all the fuses under the dash and under the hood is the starting point. It's late and I can't think right now, but try the search function. there are lots of related posts on this subject.
I believe there are 2 fuses for the 4wd, Criuse fuse and instrument panel fuse IIRC
mirrorimij
06-08-2019 03:34 PM
randrm
01-25-2011 02:51 PM
brians1bad72
12-01-2008 01:56 PM
