1992 chevy blazer s10 help please =(
![Unhappy](https://blazerforum.com/forum/images/icons/icon9.gif)
i got a probelm with my 4wd its not the toggle switch inside or the vaccum switch i even checked the tccm fuse and its good . 4hi or 4lo will not engage into position i hear the transfer case doing somthing but it wont engage into 4wd . any ideas what it could be?
thanks for reading
i also hear the clicking in the dash
thanks for reading
i have the same problem i have the to button switch it worked fine onw day then the next it didnt i found a vac hose off on the actuator under the batt tray, after hooking it up i still have no 4wd it flashes a few times but doesnt engage all i hear is the relay clicking in the dash so if you find out what urs is let me know
![Icon Couchhide](https://blazerforum.com/forum/images/smilies/icon_couchhide.gif)
If your electric t case wont engage, it can be a multitude of things.
1. bad vacuum,
2. bad/stuck shifter motor
3. TCCM/encoder is dirty/damaged.
4. poor electrical connection/bad relay
5. Damaged t case/ failed shifting mechanism.
Chances are the problem is not as terrible as described, you must check your tccm
and ensure that the motor can shift.
try this, when the assembly faults, it goes into its own "LIMP" mode, being it will only shift to 2HI and 4LO. if it will do neither then the problem may be in the relay/vacuum/or electrical harness.
Search for the term clicking in dash, or 4x4 dead, or 4x4 fix. The discussion has happened and inevitably happens again, RESEARCH RESEARCH RESEARCH!
1. bad vacuum,
[quote=Bob'sblazer;373835]If your electric t case wont engage, it can be a multitude of things.
1. bad vacuum,
i know i changed the vac switch and i chaged the switch inside i mean i hear the transfer case switching but i dont know if it engages i think its the indicator switch . ill try tomorrow . my dad has an s10 pickup ill pull the indicator switch from there and see what happens
1. bad vacuum,
![Icon Google](https://blazerforum.com/forum/images/smilies/icon_google.gif)
thanks for reading
thanks for reading
im starting to get fed up with this truck =/ but ill keep trying
Sounds like your problem is with the encoder motor, specifically the encoder itself.
If you really want to get to the bottom of the problem, check out the Tech Article (DIY) thread by error_401.
![Exclamation](https://blazerforum.com/forum/images/icons/icon4.gif)
the shaft turns but the front wheels wont lol any ideas now ? if i hold the switch down the shaft turns but it wont engage . i think its the encoder motor
btw i got the truck off the ground with 4 jacks
![Icon Hyper](https://blazerforum.com/forum/images/smilies/icon_hyper.gif)
You could start by actually using the information available on the forum...
Like the '4x4 no worky' thread that is also found in the Tech Article (DIY) section...
Yeah, the link to the Tech Article (DIY) section is right down there in my sig!
![Icon Doh](https://blazerforum.com/forum/images/smilies/icon_doh.gif)
![Icon Eek](https://blazerforum.com/forum/images/smilies/icon_eek.gif)
lol im sorry im just an 18 year old kid who owns a blazer =/ but i read it i think its just the encoder motor cuase its not engageing the transfer case to move the front hubs but the shafts moveing or can it be the indicator switch?
