1993 blazer no heat in vents
Old Jan 12, 2007 | 08:03 PM
chevyblazer4x4man's Avatar
chevyblazer4x4man is an unknown quantity at this point
Default 1993 blazer no heat in vents
i have 1993 chevy blazer s10 i changed the heater core ,radiator, thermostat,fan cluch it heats up but no hot air out of vents same with air conditioner i checked all doors and the open when needed i dont know whats next can some one help thank you chevyblazer4x4man
Old Jan 12, 2007 | 08:55 PM
20Blazer00's Avatar
Default RE: 1993 blazer no heat in vents
Check behind the glove box door. There is an arm the goes to the vent door for heat, when you rotate the heat control **** the arm should move if not then you may have a problem with the arm, motor or connections to the motor moving the door.
msfan324
Oct 19, 2012 02:27 PM
mdkuni
Oct 7, 2008 10:01 AM
SnowRemorse
Sep 8, 2008 07:30 PM
yackel
Feb 12, 2008 06:14 AM
clone432
Feb 1, 2007 11:29 PM
