1993 s10 blazer only starts if I keep my foot on the gas
Old Jan 12, 2017 | 05:50 PM
newguy's Avatar
Originally Posted by Brody Williams
Took the plenum off and checked everything looked a little clean on the drivers side put it all back together and same thing no start I did spray a little intake cleaner in before I tried to start it and it tried to fire up but seemed to die after that ran out so guess I'll start to look into fuel pump issues
side note I talked to my buddy the previous owner and he told me that he replaced the fuel pump 3 TIMES it would run for about an hour or so but then he would try and fire it up and again same no start no idle every time he did it
Its supossed to be carbon black under the plenum, not clean. Clean means its leaking fuel and washing off the corbon buildup scroll down to post 9. newer truck but same idea. thats what it should not look like https://blazerforum.com/forum/2nd-ge...h-smell-45052/
Old Jan 12, 2017 | 10:35 PM
Brody Williams's Avatar
Brody Williams is on a distinguished road
It was late last night when I typed that out and not sure why but I skipped over the fact that I noticed it being a little lighter under the regulator so I went ahead and replaced that and re checked all my spider injector connections and everything looked good put it all back together turned the key and still nothing however I could get it to attempt to start with a little intake cleaner
Old Jan 13, 2017 | 07:43 AM
newguy's Avatar
so if it will start with intake cleaner that proves its a fuel delivery problem. If the reg. is good and theres no leaks, go back to the pump. Even new pumps can be bad
chadd77
Nov 2, 2015 06:51 AM
LannyL81
Aug 21, 2012 10:37 AM
NYCJUDGE
Aug 28, 2011 04:35 PM
brian2337
Mar 11, 2008 09:46 PM
Gonzo7
Dec 28, 2006 04:17 AM
