1994 blazer rough idle, no power
Old Jul 21, 2019 | 10:10 AM
Will&jess's Avatar
Will&jess is on a distinguished road
Default 1994 blazer rough idle, no power
My 94' blazer has the 4.3 vortex and has a rough idle when starting and no power when applying the accelerator. It try to stall when you hit the gas and only does about 8 mph when we put the accelerator to the floor. We have replace coil, ignition module, cap and rotor, map, idle position sensor, fuel filter, have clean the EGR valve, and have replaced spider injectors. We are at the point the where we have no ideas. Any help is greatly appreciated
Old Jul 25, 2019 | 02:25 PM
I'm not sure if I'm just not seeing it, or you haven't touched the pump yet. Wondering if its weak..
Old Nov 16, 2019 | 11:48 PM
lilqueasy's Avatar
lilqueasy is on a distinguished road
I've had this problem with a '94, turned out my o2 sensors were cut off by previous owner AND the fuel pump was trash. I'd do a fuel compression test if I were you; super easy and can at least eliminate or confirm that there's a problem in the fuel delivery system.
Old Mar 11, 2020 | 08:35 PM
kc8oye's Avatar
kc8oye is on a distinguished road
Sounds like doing a fuel pressure test and leak down test might be a good start.
Old Mar 11, 2020 | 09:01 PM
OP hasn't been on since 7/21/19... think this thread should get closed lol...
Shawnf92
Oct 23, 2014 02:05 PM
blazerpimping
Jul 6, 2010 08:39 PM
red blazer
Dec 22, 2009 03:06 PM
Brian J. Lesko
Jan 25, 2007 02:43 AM
Mbastet99
16
Apr 24, 2006 02:37 AM
