1994 s10 Blazer->Float fuel gauge and temp gauge not moving!
Old Mar 6, 2008 | 07:23 PM
Mulisha's Avatar
Mulisha is an unknown quantity at this point
Default 1994 s10 Blazer->Float fuel gauge and temp gauge not moving!
I have a 1994 chevy s10 Blazer LT Tahoe and my analog fuel gauge floats horribly and my temperature gauge is not moving period and believe is setting off my check engine light every once in a while. Just bought the blazer and the fuel pump and gas tank have been changed by previous owner. Anything would help. Thanks
Old Mar 6, 2008 | 09:48 PM
94blazer4.3ho's Avatar
94blazer4.3ho is an unknown quantity at this point
Default RE: 1994 s10 Blazer->Float fuel gauge and temp gauge not moving!
Well for your fule gauge problem your out of luck, GM's fule sending unit are popular for having faults.Unless you replace the sending unitof course.For nowI have dicided to livewith the problem.As for the temperature gauge, you could replace the sending unit. Witch is fairly easy, and inexpencive. This sensor will set off the check engine light. Code 14 for high temp, or 15 for low. hope this helps.
Old Mar 6, 2008 | 10:39 PM
eddiegreeny's Avatar
eddiegreeny is an unknown quantity at this point
i changed my pump last year and my guage doest work. dont know if it is bad ground cuz i cut the wire, or what
Old Mar 7, 2008 | 03:19 PM
Mulisha's Avatar
I grinded down my ground location and it seemed to help a little but still floating. And where is the sending unit for me temp gauge.
Old Mar 13, 2008 | 12:29 AM
ATP's Avatar
ATP
ATP is an unknown quantity at this point
I have the same problem with my temp guage, it doesnt seem to move, and my fuel guage is kinda unreliable as well. Damn you GM.
Old Mar 24, 2008 | 09:14 PM
Mulisha's Avatar
I found out why the fuel guage is floating on the 1983-1994 s-10 blazers, By told through a GM dealer that year of vehicle does not have a "balast" or a little cup around the sending unit that has holes in the bottom of it for gas to enter. The balast is suppose to stop the wave of the gas in your tank from effecting your sending unit to keep your gauge steady. So there is one problem solved on to the next one.
smtits
Jul 5, 2011 11:18 AM
zakm0n
Jan 9, 2011 07:31 PM
rogggg1020
Nov 21, 2008 07:00 AM
Danketch71
Mar 13, 2008 09:18 PM
ytsurkytsur
Jun 23, 2006 08:33 PM
