2.8 runs bad, need help
Old Oct 20, 2009 | 12:40 PM
Baja Blazer 85's Avatar
Baja Blazer 85 is on a distinguished road
Default 2.8 runs bad, need help
1985 Chevy Blazer s10, 2.8L, 4x4. On Friday I took it mudding and got it covered with water inside and out. These symptoms began to show up a few hours after.
Saturday and Sunday's Symptoms:
Started up fine, runs okay below 1500rpm. Rev it up and it stumbles, occationally stalls, even when engine is warm. Floor it, and it pauses above 1500, and shortly after continues to max rpm, no problem. Same symptoms occur when I put it in gear and drive it.
What I did:
Spark plug wires, fuel filter. Drove it 50 miles hoping it would blow out anything in the system. I also switched from 10w-30 to 10w-40 oil (not to fix the problem, I was planning on doing this anyway, she's got high miles)
Monday's symptoms:
Doesn't start at all.
What I did after that:
My friend who works at a garage diagnosed it and determined it was the distributor. Distributor replaced. Spark plugs are perfectly fine as well as the contact points on the distributor cap.
Still won't start.
Final thoughts
It could be the coil, or the primary choke puller, but I dont want to spend the $$$ and have it still broken.
Thanks so much for any help guys! This is my daily driver and I have absolutely no way of getting to work/school otherwise. Fortunatly I'm sick so I don't need to....but that won't last long.
Old Oct 21, 2009 | 11:54 AM
Update...
Yesterday afternoon, we got it running briefly, but I shut it off because I'm stupid, and we couldn't get it started again. I cant say how well it ran, didnt drive it.
Possibly flooded, but the battery went dead so we cant prove that untill we recharge it.
Old Oct 22, 2009 | 11:36 AM
Sunshine Coaster's Avatar
Sunshine Coaster is an unknown quantity at this point
Have you got a catalytic conv. on it? If so, when you went off-roading is there a chance you smacked it? Mine busted up and acted like a check valve to the motor, wouldn't go over 12-1500 rpm because of the back-pressure in the exhaust. You also could have got moisture into - under something important and it hasn't dried out yet, for this try taking a hair dryer to all the ignition parts. The only other thing would be fuel supply, the jostling around might have shook something loose in the tank and it's stuck in the pick-up screen. Good luck with this...
Old Oct 22, 2009 | 12:38 PM
We replaced the coil, and did some timing adjustments, problem all solved!
I went offroading with it and had my exhaust fully submerged in water for at least 10 minutes at times.
Although everything is fixed now, every time I start it up, a puff of black smoke comes out the back I think its the cat
barnesto
31
Jun 11, 2014 07:12 PM
fnbutch
Jun 25, 2013 12:08 AM
billycams89
22
Feb 4, 2012 01:16 PM
zakm0n
Jan 10, 2011 11:42 AM
95s10bazer w motor
Feb 27, 2006 03:03 PM
