4wd Help
Old Nov 17, 2011 | 11:04 AM
UnknownFish's Avatar
UnknownFish is on a distinguished road
Default 4wd Help
I was wondering if anyone has converted there electronic transfer case to a manual transfer case and if so was it difficult to do?
I have been having trouble getting into 4hi but can get into 4lo, have replaced the encoder motor, vacuum switch on transfer case, front axle switch and the vacuum actuator under the battery and cleared the codes but it still won't shift into 4hi and I have run out of ideas, I did all this last winter then gave up as it got to cold to lay on the ground, I checked the codes again today and am getting code 2 encoder motor.
This is a 94 s10 blazer Vin w.
Last edited by UnknownFish; Nov 17, 2011 at 11:42 AM. Reason: forgot to mention year
Old Nov 17, 2011 | 08:44 PM
burning_soul07's Avatar
burning_soul07 is on a distinguished road
I would check the wiring going from the encoder motor to the 4x4 computer. It seems like the computer is not getting signal from the encoder when it hits 4hi telling it to stop.
Old Nov 20, 2011 | 07:55 PM
bertrenolds's Avatar
bertrenolds has a little shameless behavior in the past
Are you sure you have all your vacuum lines connected and no vacuum leaks?
2001 ZR2
Jan 16, 2010 12:39 PM
LJ809
Nov 25, 2009 08:43 AM
1badblaze
Sep 29, 2008 05:50 PM
aspenrebel
Dec 12, 2007 05:52 PM
Mikes1Addiction
Jan 12, 2007 02:08 PM
