4x4 shift problems...
Old Dec 16, 2008 | 08:03 PM
EljayK004's Avatar
EljayK004 is an unknown quantity at this point
Default 4x4 shift problems...
I think I've got a new one for everyone here...
I've got a '94 S-10 Blazer, 4.3L W code, auto trans, 4x4
The issue is, when I go to shift into 4hi nothing happens, but if I shift into 4lo while in neutral it shifts into lo just fine. When I hit the 4hi button, only in neutral, the lights blink a couple of times (two or three), but nothing happens. If I'm in any other gear, I don't even hear the normal click that goes with pushing the button.
I also had an issue getting it out of 4lo last weekend. The 4hi worked when I pushed it a week ago, but didn't when I went to use it about an hour later, however 4lo worked fine except that it didn't want to come right out.
Any ideas?
Old Dec 21, 2008 | 08:35 PM
myronhntr80's Avatar
myronhntr80 is an unknown quantity at this point
Default RE: 4x4 shift problems...
I have the same problem. No four hi, but have lo. I can hear the transfer case motor for just a split second and then...nothing. I am wondering if it may be a vacuum problem. I really don't want to have to replace the transfer case motor.
Old Dec 21, 2008 | 08:43 PM
Both of you may want to check out THIS THREAD as it runs down the diagnostic chart for a No Mode Switch condition.
Digitized
Jan 12, 2014 12:07 PM
brendan127
Mar 27, 2013 05:37 PM
Tinted
35
Feb 7, 2011 01:12 PM
riggermm
Nov 4, 2009 06:06 PM
Blahman20
Nov 3, 2008 09:45 PM
