'84 Blazer Won't Start
Old Oct 17, 2010 | 12:21 PM
I Slap Fat Kids's Avatar
I Slap Fat Kids is on a distinguished road
Default '84 Blazer Won't Start
Two days ago I bought an '84 S10 Blazer (2.8L) as a project vehicle. When I bought the vehicle, I was told that it needed the fuel filter replaced, so I replaced that and the air filter yesterday. After doing that, it was driving like a dream. However, last night I pulled into a parking lot and the engine died. I stopped and turned the key and it started up fine. Then, shortly thereafter, we went through a small bump while making a turn (it was just a gutter that went across the street) and the engine died again. This time, though, it wouldn't start back up. It would sound like it was going to start, then run for ~1 second and die again. I popped the hood and pulled the throttle, listening for the hissing of the fuel, but I heard nothing. We pushed it to a nearby friend's house and let it sit there overnight, but when I came back to it, it still wouldn't start. Now it won't even sound like it is going to start. The starter and other power accessories work, and it's got a good charge in the battery.
Does anybody know how this might be fixed? I need to get it running ASAP.
Old Oct 17, 2010 | 02:16 PM
If anyone could provide me with a diagram (or a few) of all of the fuel lines on the vehicle, it would be greatly appreciated. I've been looking around, but I've had no luck. I get the feeling that something came loose somewhere along the lines.
Old Oct 17, 2010 | 08:22 PM
abig84's Avatar
it should have a carb still I'm guessing? If so if its probably the fuel pump. Pour like a tablepoon of fuel in the carb and see if it'll fire. If so your fuel pump went out or your outta gas. If a line came loose you'd smell gas strongly. A old trick was to pull the line going to the carb off and crank the engine to see If gas comes out. Thatll let you know if the pump is spraying. On my 85 I got one of those clear filters by the carb so if its not getting gas ill know
Old Oct 18, 2010 | 08:09 AM
Thanks, I'll check that. The previous owner told me he just replaced the pump thinking that it was the problem (real problem was fuel filter).
Old Oct 18, 2010 | 05:55 PM
No ****. I feel dumb. Mechanical fuel pumps won't feed fuel if you run out, even if you refill it...
Thanks
[/thread]
andrewrj
May 6, 2012 07:28 PM
princered72
Sep 13, 2011 10:36 AM
Dark Rider
Aug 8, 2010 11:57 PM
1BSBAKER
Aug 11, 2009 10:54 AM
Irish10Hockey
Nov 13, 2008 02:48 PM
