'86 blazer S10 2.8 Jasper v6 oil in radiator
Old Nov 1, 2014 | 04:47 PM
David NM's Avatar
David NM is on a distinguished road
Default '86 blazer S10 2.8 Jasper v6 oil in radiator
I bought an '86 Blazer that had a new Jasper 2.8L V6 installed in 07. The problem is oil is pumping into the cooling system...previous owner said the intake manifold gasket needs replaced...new radiator, new hoses new thermostat and about $9000.00 worth of work he has done to it..I have all the receipts..I wanted to test it myself so I topped off the coolant system and the oil was full...looked brand new...at start up it cranked over and started but had a backfire popping coming from carburetor..engine seemed to have good compression..could the intake manifold gasket failure cause the oil in radiator..and the backfire be a miss adjusted valve or sticking valve? Also there is no coolant in the oil.
Little Roober
Dec 16, 2011 08:45 PM
Jonboy
May 13, 2011 09:28 AM
Skeeter Cruz
Mar 1, 2010 07:48 PM
Mr Blazer LT
Jan 6, 2008 04:07 PM
Im_Bryan
May 4, 2005 02:08 AM
