87 Blzr shakes/ white/green leak from radiator tube to block
Old Feb 11, 2012 | 08:17 PM
87Blzr's Avatar
87Blzr is on a distinguished road
Question 87 Blzr shakes/ white/green leak from radiator tube to block
I have a 87 s10 blazer, haven't had any problems until last night. It started shaking when I was driving (worse in 2nd gear), today when we looked at it, there is a white/green/ grey colored "stuff" coming out of the head from the radiator hose (the upper hose). Hoping someone would know where to lead me to start trouble shooting.
Old Feb 11, 2012 | 11:52 PM
bigkhans's Avatar
bigkhans is on a distinguished road
Check your oil cap and make sure that there's no foam on it. If there is then you've got a blown head gasket. Also a few pics would help too. This also happens when stop leak has been added to the antifreeze.
Old Feb 12, 2012 | 05:19 AM
neo71665's Avatar
Sounds like a blown head gasket.
Old Feb 12, 2012 | 04:10 PM
87Blzr's Avatar
Default 87 blazer probs
I checked the oil cap and there is no foam on it. Also, the oil color is ok, and aniti-freeze. I took a couple of pictures, and read a few signs on head gasket, and the foam was the only symptom. So, was hoping it could be something else? We haven't added any stop leak to the antifreeze but we bought this blazer a few months ago. Haven't had any other problems but were told the water pump would need to be replaced soon, could that cause this problem? Thank you for your help
Attached Thumbnails 87 Blzr shakes/ white/green leak from radiator tube to block-sam_1327.jpg   87 Blzr shakes/ white/green leak from radiator tube to block-sam_1328.jpg   87 Blzr shakes/ white/green leak from radiator tube to block-sam_1329.jpg   87 Blzr shakes/ white/green leak from radiator tube to block-sam_1330.jpg
Old Feb 12, 2012 | 08:26 PM
bigkhans's Avatar
What motor is this? A 2.8? It could be that the previous owner used stop leak and then changed all of the fluids before you bought it. I'm still leaning towards a blown head gasket. Or it could also be that the head gasket is old and brittle and is just now starting to fail.
razman
Dec 30, 2014 10:14 PM
bigdaddykane93
Jan 4, 2010 12:03 PM
lil_blazin
May 10, 2009 05:20 PM
jbelllive
Jun 21, 2008 11:25 PM
WyteNyte
Feb 16, 2006 05:32 PM
