88 4.3 blazer not firing
Old Oct 28, 2009 | 03:47 PM
Tooth_pic's Avatar
Tooth_pic is on a distinguished road
Default 88 4.3 blazer not firing
Ok so im like one day old on this site.. I found a few threads that helped me rule out some stuff, but now im in an area ware i need help.
So i have an 88 4.3L blazer. It was given to me for free from a good friend of mine like 5 months ago. I changed the oil and drove it from Seattle Wa. to the east coast and back. 8000 and somthing miles, ran like a top. I got home and after about 2 weeks, i was driving down the road, started sputtering, backfired a few times(no throttle response) and died. got it to my house and so far i have verified that it has fuel making it to the throttle body, and has spark, but will not fire at all. i think its the injectors but idk.. any help would be great. Im not a complete novice but this will be a bit of a project for me
thanks a bunch,
Elijah
Old Oct 28, 2009 | 05:43 PM
Test the fuel pressure. It needs to be 8-10psi for the injectors to properly feed the engine.
Does it run with starter fluid?
Old Oct 30, 2009 | 01:57 AM
Tooth_pic's Avatar
ok so i had a friend of mine com over today. we worked on it in the rain for a few hours and found that the distributor was corroded to ****.. sanded on it a bunch and got it to fire a few times. will have the rest of the parts in the morning and then see what happens
Old Nov 5, 2009 | 06:07 PM
Tooth_pic's Avatar
ok ended up having to buy a whole new distributor.. having a hell of a time trying to get it timed. cant even get it to fire once. any help would be greatly appriciated
Old Nov 5, 2009 | 06:10 PM
There isn't much to getting it timed. Mark the position of the #1 plug wire terminal on the base of the distributor. Rotate the engine over to TDC #1 on the compression stroke (both valves closed). Drop the distributor in so that the rotor points at the mark on the base of the distributor. You may have to reposition the oil pump drive so that it fits properly into the end of the distributor, but other than that...
Old Nov 6, 2009 | 02:58 PM
Tooth_pic's Avatar
so i pretty much have to pull the valve cover then? any way to do it w/ out?
i think i my have had it at tdc on exhaust stroke, which is very possible. thanks a bunch for the help.
Old Nov 6, 2009 | 05:01 PM
Blazin_Jason's Avatar
Also unplug the wire underneath the pass side carpet when you set the timing.
Old Nov 6, 2009 | 05:30 PM
Yes, most definitely. Gotta get the distributor in properly first, but you cannot skip disconnecting the timing wire prior to setting the timing with a timing light.
Old Nov 12, 2009 | 10:53 PM
Tooth_pic's Avatar
ok so i took my valve cover off, brought it to tdc on the compression stroke, and dropped the distributor it. after aligning the oil pump rod the rotor pointed right at my number one. i put everything back together and, nothing. with a timing light on it im hitting right ware i should be but its not firing. I have the wire unplugged and just put a new battery in, and nothing. also i have 2 marks on.. about 90 degrees apart from each other.. i have been using the one that comes first. is this wrong?
Old Nov 13, 2009 | 12:45 AM
So it just cranks and doesn't even try to light? I would try putting a little gas or starting fluid in the TB and try it. You said it does have spark? Is that at the plugs? Make sure that the distributor plugs are all good, they might be corroded as well.
