88 with power window problem
Old Mar 24, 2009 | 08:52 PM
potts's Avatar
potts is on a distinguished road
Default 88 with power window problem
Just got an 88, have a power window problem. We put a new motor in tonight thinking the old motor was bad. I would only go down about 2 inches. The new motor will lower the window all the way but will not go up at all. Without the window attachments and only the motor it will still not go up only down.
I tested the back of the switch with both a test light and ohm meter and got some crazy readings.
Has anyone else tried to test these the voltage and resistance on the switches?
Thanks for any assistance!
Potts
Old Mar 25, 2009 | 07:45 AM
It is a direct switch (ie no resistors, etc in the line). There should be direct continuity across the switched terminals when in a particular position. If it is not doing this, the switch is likely bad.
bigslik20
Aug 9, 2011 11:32 AM
chrisjanicki01
Nov 14, 2009 05:45 PM
mightymo61
Aug 3, 2009 02:58 PM
mightymo61
Feb 21, 2009 07:27 PM
stingra65
Jul 25, 2007 07:52 PM
