88 S10 Blazer
Old Jan 30, 2006 | 08:36 PM
matt_87_s10_blazer's Avatar
matt_87_s10_blazer is an unknown quantity at this point
Default RE: 88 S10 Blazer
how much was the kit?
Old Feb 1, 2006 | 01:27 AM
blazerv8's Avatar
blazerv8 is an unknown quantity at this point
I don't remember for sure.You can check on wwwJTR.com That should be the site.
Old Feb 1, 2006 | 01:43 AM
will the 5 speed 2.8 tranny with the bellhousing to bolt up hold up to the power of a 350 or do i need one from a 4.3?
Old Feb 1, 2006 | 10:35 AM
blazerv8's Avatar
The 2.8 has a totally different bellhousing than the 4.3 & V8's.The 2.8 is a 60 degree V6.The 4.3 & V8's are 90 degree.It won't work.
Old Feb 2, 2006 | 03:09 AM
Hanr3's Avatar
To answer your original question. Should be a matter of motor mounts, tranny mount, exhaust pipes, and puter. Teh 4.3L radiaotr willwork provided both engines are serp set-ups (verify the input and outputs of the rad matches the water pump). Swap the puter and wiring harness.
Your t-case should bolt up to the back of the tranny just fine. The only difference between the 2.8L 700R4 and the 4.3L 700R4 is the bolt patern on the bellhousing. You can take the inernals out of either and swap them into th other one. They are identical except for the case.
Old Feb 3, 2006 | 02:06 AM
ok cool thanx alot guys
Dallas1970
Feb 22, 2019 05:05 PM
94BlazerGirl
Aug 28, 2014 06:14 PM
rfine67
Aug 13, 2011 01:04 PM
ricky
Jul 22, 2010 08:04 PM
1994BlazerS10
Mar 3, 2010 08:52 AM
