88 S10 surges at normal speed
Old Mar 2, 2011 | 05:21 PM
Braddunagan's Avatar
Braddunagan is on a distinguished road
Default 88 S10 surges at normal speed
I fixed one problem and now I have another. My 88 S10 Blazer surges when you get up to normal speed with only light pressure on the pedal. I thought it was the shift cable on the tranny so I adjusted that. It improved the shift but still surges. It seems to want to downshift/upshift. It is annoying the bejeezus out of me! If I pull the tranny down into D it stops but then it revs too high on the expressway and uses too much fuel. Any thoughts?
Old Mar 3, 2011 | 09:37 PM
J.R. Clay's Avatar
J.R. Clay is on a distinguished road
I am a Newb But it sounds Like a Vacuum issue to me.
Other Things to Check:
Check inside The plenum for leaking Fuel pressure regulator , Fuel Hoses, Injector Nozzels, a small leak may do Just That.
Check Vacuum, EGR Valve, and Computer Codes for a bad sensor maybe.
dont overlook The PVC Valve either.
Pipewrench Dale
Nov 10, 2014 06:16 PM
jdub9000
Jul 22, 2013 07:58 AM
proper
Jan 13, 2010 06:49 PM
filthy sanches
Oct 29, 2009 05:52 PM
