89 Jimmy 4.3 stumbles when shifting into 2nd
Old Feb 16, 2010 | 07:20 PM
william70d's Avatar
william70d is on a distinguished road
Default 89 Jimmy 4.3 stumbles when shifting into 2nd
I have recently aquired a 89 jimmy 4x4 with the 4.3 v6. The rig has a new motor and new trans. less than 200 on the motor. It has a msd probillet distributor with blaster coil. It had a holley aftermarket throttle body on it. When I purchaed it, it ran horribly. The holley throttle body was junk. I went to the salvage yard got a factory throttle body and it works great now. My problem is that when the rig shifts into second gear it stumbles for a minute and then recovers. It starts beautifully and runs good. It doesnt stumble under moderate to full acceleration, just when you are easing around (normal driving). Check engine lights are off.....untill you get on the highway at highway speeds. I get an engine code 13 and a code 33. The map is new, the tps is new, the o2 sensor is new, the iac is new. I cant keep the codes from coming back up. The timing is good. I dont know what else to check. I changed plugs and wires the other day. The plugs seemed to me like the engine was running a little lean. I have no way of checking fuel pressure.
Anyone have any suggestions
Also my 4wd all of a sudden has quit working. Transfer case is good, the front hubs just wont lock in. Never worked on one of these before. Let me know what yall think?
Old Feb 16, 2010 | 08:01 PM
Ryanmatt135's Avatar
Ryanmatt135 is an unknown quantity at this point
code 13 - open oxygen sensor circut
code 33 - MAP sensor signal voltage high
the attached pics include a wiring diagram and flow chart for your codes. hope this helps.
Attached Thumbnails 89 Jimmy 4.3 stumbles when shifting into 2nd-graphic.gif   89 Jimmy 4.3 stumbles when shifting into 2nd-graphic-map.gif
Old Feb 16, 2010 | 08:32 PM
william70d's Avatar
for some reason I cant open the first diagram you listed. I will check out the one for the map when I get a chance
Old Feb 16, 2010 | 08:36 PM
02 sensor wiring diagram and flow chart
http://img693.imageshack.us/img693/3276/graphic.gif
Old Feb 16, 2010 | 10:11 PM
ohsofly's Avatar
Are your hubs manual or auto locking?
Old Feb 17, 2010 | 06:08 AM
4x4 No Worky.... Maybe this will help....
They would be vacuum engaged just like all of the other 4wd s-series trucks.
Old Feb 17, 2010 | 04:37 PM
william70d's Avatar
hubs are automatic, does anyone make a manual conversion for them?
also thanks for the flow charts, when I get time I will see whats going on with this thing
Last edited by swartlkk; Feb 17, 2010 at 04:45 PM. Reason: *Combining Consecutive Posts* - Please use the EDIT function to add additional information to your post if another member has yet to reply.
Old Feb 17, 2010 | 04:55 PM
The engagement of the front axle happens inside the passenger side extension tube. You could make it manual with a posi-lock setup (check in the Tech Article DIY section). Due to the hub style that is used on these trucks, there are no manual locking hubs like there are on the solid front axle trucks.
brdmh44
Jun 23, 2015 04:47 PM
raleighjimmy
Aug 22, 2012 07:30 PM
stepjl
Sep 25, 2010 12:17 AM
75 blazer
Aug 13, 2010 06:36 AM
96jimmy4x4in
Oct 7, 2007 09:23 PM
