91 Chevy Blazer 4.3
I need some help, my truck will crank but it skips very bad and then stops running again. The only light reading is the check gauges light. My oil pressure gauge reads zero but I have oil on the dipstick. As I said it won't run either, I was wondering if it was possibly the oil pressure sensor sending a bad reading to the computer keeping it from running. I've also been told to check the oil pump itself, and the fuel pump but I believe i've heard the fuel pump running. Am I right or could it be something else?
Your oil gauge reads zero while cranking the motor and while it is running?
I had a '92 with an oil pressure sending unit that went bad (pretty much all at once) and the motor ran fine although it was a long 100 mile drive back home while listening for any noise from the motor.
The oil pressure sending unit might be a separate issue from the rough running of your engine.
I'd check the initial timing on the engine to makes sure the mechanicals are lined up.
Regarding if the oil pressure is interlinked with the fuel pump, I do not know and have never heard of that being the case.
Did you ever have any luck?
If not, any other details. . was this running and driving regularly before? . . Did it stop while driving, or just came out one day and had the problem?
Did you do any work on it before experiencing the issue?
Sorry for all the questions lol. . .just trying to help if I can.
hlaverty06
03-05-2014 07:14 PM
ChevyMane808
04-05-2013 10:51 AM
