92 Blazer Fuel Injection Questions...
Old Sep 1, 2009 | 09:18 PM
Malachai's Avatar
Malachai is on a distinguished road
Default 92 Blazer Fuel Injection Questions...
I need to clean the fuel injection, so am going to go with a fuel additive, one of my friends suggested to add an octane booster at the same time as the fuel cleaner to really do the job...I dont want to sound like a bad friend or anything, but, has anyone done this? It just seems a bit overkill to put two bottles of additive in one tank of gas...suggestions?
Old Sep 5, 2009 | 01:11 AM
cjmor1804's Avatar
cjmor1804 is on a distinguished road
You can get a extra concentrated fuel additive, instead of using 2 bottles. Or, use a higher octane fuel w/ the cleaner. Also, if u have a TBI injection, the injector filters are only $4 each. And a fuel filter is about $15. I suggest buying these instead of countless bottles of additive, if somethings clogged.
Keep in mind, you would have to get new O-rings after you pull the injectors, which would require dismantleing the top of the carb (about 8 torq heads), plus a new gasket. And for the fuel filter, hopefully it wouldn't be rusted to the line so you wouldn't have to replace the line AND the filter, which i had to do (only spent $25).
Somewhat time consuming, but still less expensive than buying an $8 fuel additive every time you fill the tank!
flypaper
Dec 3, 2013 05:16 PM
francis
Dec 6, 2010 05:43 PM
NeoGeo
Feb 8, 2010 08:55 PM
SlydinClyde
Oct 20, 2009 12:56 AM
LunchBox
Jun 19, 2006 08:35 AM
