92 S-10 4.3L Power windows dont work
In my Blazer the power windows have stopped working. All of them at the same time. I have checked the fuse, it was OK, but I changed it anyway. Still no action. None of the switches in any of the doors move any window.
I have 12V over the fuse so the fault must be somewhere else.
Thanks
Jan
Thanks
Jan
I would check the master switch in the driver door for corrosion and/or a loose connection.
have you found the problem ? I just bought a 4 door and am having the same problem.
Sure you're looking at the right place in the fuse panel? Should be a circuit breaker in the slot, not a fuse.
where is the circuit breaker located, having same problem. they shut off then a hour later worked, that was Yesterday....Today same thing happened
Sorry for not updating this.
Yes I found the problem. Some previous owner had put in another fuse up the line and that one was blown. It were place high up above the kickpanel.
New fuse and it has worked since that.
On my car there is a burglar alarm installed and they have reworked the wiring a lot, it is a mess really. I guess this second fuse is part of that rewiring.
Jan
Jan
argue_with_a_tree
02-28-2011 05:57 AM
scoot
01-11-2005 02:38 AM
