93 4.3 Loping Idle, Stalls, am stumped.
Old 10-24-2008, 01:08 PM
ruxpin76's Avatar
ruxpin76 is an unknown quantity at this point
Default 93 4.3 Loping Idle, Stalls, am stumped.
Ok, in summary:
1993 Vortec 4.3 W Vin,
Work done: EGR removed and cleaned w/ new gasket, new cap and rotor, new plugs (Delco), new Spider, new nutkit, new coolant temp sensor, new IAC valve, seafoamed tank and intake, new gas, new fuel filter, new fuel pump 10K mi. ago, new connector for knock sensor.
Blazer lopes on idle, stalling, ocassionally with a few bucks/pops. If bypass mode (tan/white wires) is run, blazer stops loping, won't stall, but runs like crap.
Seems worse when cold, some days no issues.
Any thoughts? It's driving me nuts not to have my wheels and the garages around here aren't helping.
~Ted
Old 10-24-2008, 01:13 PM
Peru Motors's Avatar
Peru Motors is an unknown quantity at this point
Default RE: 93 4.3 Loping Idle, Stalls, am stumped.
no ses light other than when you unhook the pass.compartment wire? JP
Old 10-24-2008, 11:08 PM
ruxpin76's Avatar
Only get SES when timing sensor is unplugged...
Old 10-25-2008, 01:21 AM
94blueknight's Avatar
94blueknight is on a distinguished road
when u replaced the spider kit and nut kit did u notice any clean/dirty areas?
Old 10-25-2008, 09:52 AM
ruxpin76's Avatar
Pass. side near FPR was "clean", but now that spider and nutkit are replaced, neither should be an issue. Old nut kit was cracked on inside of bend, old spider seemed ok, but FPR could've been bad.
Old 10-28-2008, 10:04 PM
ruxpin76's Avatar
Problem finally solved...I think. Time will tell. Turns out it was a bad distributor (whole unit), bearing were shot, allowing movement and variable messed up timing to computer. That's why bypass worked, but problem was intermittant. Will re-post if it turns out not to be fixed... On the plus side, I've replaced all the common bad parts, so I should be good for another 150K!
youngbloodsno111
03-23-2019 07:00 AM
samadams
11-16-2014 04:32 PM
mritech
11-29-2010 08:05 PM
ruxpin76
10-08-2008 09:14 PM
see119
08-30-2005 02:00 PM
Quick Reply: 93 4.3 Loping Idle, Stalls, am stumped.
