93 4.3cpi 2wheel wont start
Old Nov 2, 2008 | 11:40 AM
billyhoe's Avatar
billyhoe is an unknown quantity at this point
Default 93 4.3cpi 2wheel wont start
i have been all over this vehicle.new fuel pump,filter,lines going into plenum,spider{fuel pressure reg,injectors}plugs,everything!it will not start.i unpluged the new fuel pressure reg to make sure gas was getting to it,turn the key,plenty of fuel.put it back together,wont fire{i have spark thats all new too}.took a spark plug out to see if the injectors were spraying,crank the key,nothing but air.weeks i have been trying to figure this out.any ideas anyone?gas tank is new also.[:@] [:@]
Old Nov 2, 2008 | 04:06 PM
Default RE: 93 4.3cpi 2wheel wont start
I have seen a few different people have problems with the electrical lines/connections inside the plenum not properly activating the injector. You may want to see if that is the cause.
Old Nov 3, 2008 | 11:03 AM
billyhoe's Avatar
how many volts should there be?
Old Nov 3, 2008 | 11:47 AM
mr.vls's Avatar
Have you checked the timing. It could have jumped time and it will never start. Bring the number 1 piston to TDC, Check that the rotor is pointing to the number 1 plug. The Rotor should be pretty close to the # 1 wire location at the distributer cap.
Old Nov 3, 2008 | 01:51 PM
billyhoe's Avatar
it starts with fluid.then dies.has perfect time.
Old Nov 3, 2008 | 02:11 PM
billyhoe's Avatar
i have 12 volts to the plug outside the plenum.im going in the plenum AGAIN to see if i have power to the injector itself.i hope i dont.
Old Nov 4, 2008 | 06:19 AM
mr.vls's Avatar
how about fuel pressure, Fuel Pump Relay, Fuel Pump Regulator.
Old Nov 4, 2008 | 08:10 AM
mr.vls's Avatar
Are injectors pulsing, I do believe you can check the Injectorpulse with a Noid light. (At least that's my understanding of a NOID Light) That would tell you if the injectors are being controlled by the computer.
Old Nov 4, 2008 | 09:38 AM
The problems that I have seen and heard about surrounded the electrical connection to the injector whether from corrosion or relaxing of the connector plastic.
Old Nov 5, 2008 | 02:11 PM
billyhoe's Avatar
i took back spider{fuel pressure reg,injectors}and got a new one just to be sure.same thing.i have fuel pressure.with the plenum off i can see the gas through the line,it makes it all the way to the spider fine.but when i hit the key,no fuel sprays out of the injectors at all.i have twelve volts to the spider as soon as i hit the key.im gonna go check the conecting clip real good,thats a good idea swart .ill be back.
