93 blazer 2wd STUMPED
Old Apr 21, 2011 | 03:00 PM
chadillac85's Avatar
chadillac85 is on a distinguished road
Default 93 blazer 2wd STUMPED
i have a 4.3 vortec just bought. i got it home after alil sputtin on drive and now cannot get to start. it has a new fuel pump, sending unit, and tank, along with distributor, iginition module, cap, rotor, plugs, wires, fuel pressure regulator, and spider injection. all these components worked good together for bout week and now i still have spark, air, and fuel but results in cranking but no fire. ive hooked gemini with pathfinder system up and every sensor is working properly but the rpms read 9999 while motor off and key in on position. there is no change in rpms even while cranking over.
i am new to site but very familiar with s10s so looking for some input as this is a new condition ive never delt with.
Old Apr 22, 2011 | 05:32 PM
update just put new ecm in and have same results. only thing left that i can think would be some wiring gremlin.
Old Apr 22, 2011 | 07:06 PM
ohsofly's Avatar
Try pulling the injector harness wires - the blue and red ones that go into the front of the manifold through a gromet. Thats an 8 dollar part and should always get changed when doing the spider. The wires that contact the injector nubs are thin like hair, I had a crooked one that made my truck not start sometimes, and just quit at random.
Old Apr 23, 2011 | 05:40 PM
injectors r workin perfectly they pulsate like supposed too. but im only gettin a change in rpms when i lift and wiggle distributor, and its not a constant change or steady. is it possible for a coil to arc on inside and send constant power threw tach wire to read such a high rpms?
Old Apr 30, 2011 | 11:23 PM
ohsofly
i replaced the ground wires at the back of the motor and got it to fire up and it still had the stutter to it. but ur correct on those wires they were the second issue to the problem.
so thanks for the advice
Old May 1, 2011 | 09:28 PM
ohsofly's Avatar
Good job. Sucks when its an 8 dollar part thats keeping you from runnin.
youngbloodsno111
Mar 23, 2019 07:00 AM
trk1363
Dec 14, 2011 08:20 PM
lushdrunk
Jun 24, 2010 11:30 PM
dback3
17
Sep 18, 2009 06:03 PM
Joey P.
Dec 21, 2006 09:23 PM
