93 Blazer 4.3 wont start
Old Mar 16, 2007 | 01:39 PM
DLVHOG's Avatar
DLVHOG is an unknown quantity at this point
Default 93 Blazer 4.3 wont start
I just bought a 93 S10 Blazer with a 4.3 that was not running. Fuel pump was not coming on, so I installed a new fuel pump. Fuel pump is coming on now but Still wont start. I can start it by spraying gas into the cpi. What should I check next?
Old Mar 16, 2007 | 05:01 PM
hillbillyinOhio's Avatar
Default RE: 93 Blazer 4.3 wont start
will the truck turn over???? check battery connections, make sure that you are getting spark at plugs.
Old Mar 16, 2007 | 05:43 PM
DLVHOG's Avatar
Yes it will crank over.It willrun if you spray into cpi also.
Old Mar 16, 2007 | 09:12 PM
have you tested the fuel pressure??? clogged injector?
Old Mar 21, 2007 | 05:33 PM
DLVHOG's Avatar
My Dad took it to a friend on a dolly , put on computer found out the fuel injection spyder is bad . Thanks for the help.
dj00140
May 20, 2013 06:37 PM
JimmyBlaze541
May 2, 2013 10:00 AM
bobby099
15
Nov 7, 2012 07:29 PM
FreeTime
Sep 8, 2012 01:38 AM
jetsmy
Aug 1, 2008 10:10 PM
